Some GTech Pro Timer results
Originally Posted by Black Blown 02
No detonation unless I turn timing up to above 18 degrees. With the same pulley and the smaller intercooler It could only handle 16 degrees. I gained 5 tenths and 4 mph with just the intercooler change. The ATI intercooler is extremely undersized!
I thought I was about done tweaking on this thing, you got my gears turning again. Thanks.......... My bank account hates this place.
So now less than one day after being happy with the current mods I am looking into:
11psi pully, intercooler upgrade, probably more plumbing, and more tuning......
You got a pic of the intercooler??
https://ls1tech.com/forums/showthrea...er+intercooler
I was looking at the G-Tech when it shifted 2-3 to get that number so maybe it is off a little. 5500 seems right, it's set to stock. I may have to send the PCM out one more time because the tranny won't downshift out of overdrive if I am going more than 65mph and floor it. If I do send it back I am going to have the WOT shifts raised too, waiting to get a dyno run and wide band to see if there is anything else that needs tweaking. It's still pulling hard when it shifts now. For my purposes the performance is fine but it would be nice to have all she's got available.
Originally Posted by Black02Z71
Did you calibrate the rpm on the G-tech?
Originally Posted by MacADaYear
Post some graphs
someotherguy
10-05-2015 12:49 PM
