Spark plug gap
mine was on the air cleaner cover. and it was .060 so thats what i gapped them at.
as for that last pic, i am afraid to ask where the rest of the spark plug went? that could be very damaging!!!
My 2004 4.8 has AC irridiums at .040 . I checked the new ones for .040 ;I hope it didn't rub any irridium off. Can that really happen?
I believe the 41-985s were superseded by 41-110. The gap remains the same. This bulletin has been updated to cover models through 2009.
Document ID# 1396703
Subject: Information on New Spark Plugs and Gapping #03-06-04-060 - (10/24/2003)
Models: 2004 Buick Ranier
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
2004 Cadillac CTS-V
1997-2004 Chevrolet Corvette
1998-2002 Chevrolet Camaro
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche
2003-2004 Chevrolet Express, TrailBlazer
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon XL
2001-2004 GMC Yukon Denali, Yukon XL Denali
2002-2004 GMC Sierra Denali
2003-2004 GMC Envoy XL
1998-2002 Pontiac Firebird
2004 Pontiac GTO
2003-2004 Hummer H2
with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
2004 Cadillac CTS-V
2004 Pontiac GTO
2003-2004 Hummer H2
PT's Slowest Truck
Yessir, different years have different gaps as different years have different plugs I remember the spark dwell tables that you posted and just thought of something...I know that it probably makes very little difference, but if you hypothetically have a 99 with platinum plugs gapped at .060, and you switched to iridium plugs, you should leave the gap at .040, and change the spark dwell tables in the tune to be totally accurate...something to ponder
