Speartech Idler relocation bracket
Originally Posted by mwalls54
Speartech still has some in stock, i just bought one a couple of weeks ago. Just call and talk to John
Originally Posted by sdimess84
Is the ls6 intake really worth it? About how much does it cost roughly to do the ls6 intake swap?
you will need to buy some hoses, for the Throttle body baypass(if you have allready done this)
and the Evap
also hose for the PCV as well
you will need to find some round shanks about 2to 2-1/2" long to use as stand offs for the fuel rails..
you will need to extend your radiator hose.
Find you a spear Tech or similar pulley relocation bracket
a new longer serpentine belt
a throttle cable bracket
a freeze plug for the egr hole
the Intake ( given)
teflon tape.
misc. barbs for the hoses..
hose clamps
black RTV sealant.
ARP intake bolts
brake cleaner, or any type of cleaner to clean the heads before you set the intake down.
Tie Wraps
Misc screws and nuts( i used 10/32X1" screws and nuts for the throttle cable bracket)
that should get you a parts list to see how much it will run you..
I wish I could give you a total, but I bought the whole setup, off of a friend, and got a hell of a deal on it..
so what I am paying for it, and what you might pay for are going to be diffrent.
KINGCYCLES
10-02-2015 11:21 AM
SlvrSierra4.8
10-01-2015 10:39 PM
