Specials on Baer Eradispeeds and The Other Guys headers
Old 06-18-2003 | 11:29 AM
tbyrne's Avatar
Default Specials on Baer Eradispeeds and The Other Guys headers
We are offering discounts on all of Baer's GM Truck Eradispeed rotors and The Other Guys mid length headers. These specials will be running until Sunday, June 29th and everything will be ordered on the 30th. I can't post pricing for these specials but can send you the price list if you send an e-mail to tbyrne@tbyrne.com.
Part numbers for the Baer rotors that this applies to is -
2301028 -
GM 1999-'02 1/2 ton full size pickup front
GM 2000-'03 1/2 ton SVU front
2302024 -
GM 2000-'01 1/2 ton 2WD SUV rear
GM 2000-'03 1/2 ton 4WD SUV rear
2302037 -
GM 2002-'03 1/2 ton 2WD SUV rear
Baer Brake Systems, the leader in automotive braking systems is proud to announce the introduction of the EradiSpeed+1 upsized rotor package for the latest generation of GM ½ ton truck and SUV applications. These performance rotors feature LITE™ (Low Inertia / Thermally Efficient) technology. Two piece rotors have anodized billet aluminum hats with re-useable stainless N.A.S. aircraft hardware. Designed specifically for use with popular 18-22-inch wheels, EradiSpeed+1's feature massive 14" diameter rotors front and rear, along with all the custom hardware to make installation quick and easy. EradiSpeed+1 rotors are also "cosmetically enhanced" with cross-drilled, slotted and zinc washed surfaces.
Cast from a high friction iron alloy, EradiSpeed+1 rotors are designed with more mass for heat absorption, are directionally ventilated for increased pumping efficiency and feature billet or forged aluminum centers, which reduce overall rotor weight. By eliminating the weight at the center of the stock iron rotor, Baer is able to cast the rotor with more mass in the "fire path," (where the pads contact the rotor,) allowing substantially more heat to be absorbed into the rotor. Balancing and heat-treating, coupled with the increased pumping efficiency of directional vanes (vents), ensure that EradiSpeed+1 rotors deliver substantial performance benefits.
Many of today's vehicles using larger wheels experience drastic reductions in braking ability due to the additional weight of the wheel...sometimes up to 35 pounds per wheel. With its larger rotor size, EradiSpeed+1 rotors are able to regain even more than the original braking performance. Best of all there is no need to bleed the system after installation.
When you inspect the quality, appearance, performance and durability, you'll see that Baer's EradiSpeed+1 rotors are a desirable and high value upgrade. In addition, Baer is so sure of the EradiSpeed's functional merit, that it provides a Limited Lifetime Warranty against warping. No other performance rotor manufacturer on the planet offers such protection.
There are many part numbers available for The Other Guys headers. Check our website for the part number for your vehicle.
You’ll enjoy increased performance and fuel economy secure in the knowledge that The Other Guys long tube headers are manufactured to the industry’s highest standards.
Available for 1989-2002:4.6L-8.1L GMC, Chevrolet Light trucks & SUV’s
14-gauge mild steel
Electroless-nickel-plated
Titanium-thermal-barrier-ceramic
Corrosion and heat resistant
1/2” thick precision-cut flanges
50-state legal
Gain of up to 43 horsepower
California Air Resources Board (CARB) Exemption No. D-509
Exhaust flanges are made from beefy 1/2" thick steel plate (50–100% thicker than most others) and ground flat.
Thick 14-gauge tubing is used instead of ordinary 16 or 18-gauge. Tubes are precision TIG welded to the flange.
A.I.R. refers to factory installed air pump emissions systems.
A special Electroless nickel plating is used inside and out and a durable high temp coating is available. This is twice as durable as stainless steel. These headers are so well built, they’re backed by an un-limited lifetime warranty – the best in the business.
Have a good day,
Tom
BKnBLK05
12-28-2015 09:52 PM
Go5.3tt06
09-12-2015 10:29 AM
fillpot
07-26-2015 08:21 PM
lxcoupe
07-21-2015 03:12 AM
GM-only
07-19-2015 11:48 PM
