Speed Engineering True Dual Exhaust Prototype..
#32
How many o2 bungs does the y pipe have just wondering if it's possible to install a wideband in conjunction with the two upstream o2's. That kit looks killer I wanna hear these mufflers
#34
slick_sierra: The headers have O2 bungs in the collectors for the front O2 sensors, and we added an additional bung by the pan for wideband tuning.
ezdaar: Ya, one of the items we're adjusting is dropping the cross over pipe under the transmission. If you look the pipe is higher on the passenger side than the drivers side. It fits fine with the 4L60E, but it will probably hit on the 6 speed transmissions. So we're dropping it down 1" to give as much clearance as possible.
Thanks
Sean
Thanks
Sean
#38
Ya, we wanted to start with the best performance exhaust possible. The nice thing is if it's too loud for you, you can always swap out the mufflers pretty easily and still use the entire stainless system.
ezdaar: I honestly didn't look. I am sure it will be the same as using most aftermarket Y-Pipes.
Thanks
Sean
Thanks
Sean
