Speed Engineering True Dual Exhaust Prototype..
#393
Ya, the clamps will work even with the wedge. They are just a pain to get on. We have already informed the factory to add some length to the straps. Those should be updated on future batches. The wideband O2 bung was also welded up a little to far. Not sure why they did that. The prototype was welded just fine. They have been informed about that as well. Everything else we have checked/tested should be good to go. We have installed 3 of them on different vehicles so far, plus the ones going out to you guys successfully. If we come across anything else we will continue to perfect our kit. Thanks for the input..
Sean
Sean
#400
12 Second Club
What is the length difference between the RCSB version and extended cab?
I'm looking to order one for my '05 2500HD Reg Cab w/ 8ft bed. Not sure which set-up I should run. My current set-up is dumping at about the same spot as the RCSB version, but I'd like to go a bit further back.
