Speed Engineering True Dual Exhaust Prototype..
#713
Question, did you guys used the metal gaskets and bolts that SE sells with these headers or some alternative.
I was told by a couple buddies that the stock bolts are recommended, but whhat about gaskets?
#714
Just so I am clear. If I want to do a whole exhaust (headers through tailpipe) I only need the headers ($279) and true duel rear exit ($495). The Y pipe comes in the true duels kit?
09 2500hd 6.0 4x4 6 speed
#716
Use oe gm manifold gaskets metal
#719
10 Second Club
Also if you are not going to use header collector ball flange highly recommended,(Flowmaster 15930: Header Collector Ball Flange Kit 3" Collector to 3" Tubing | JEGS) then use lap band clamps.
#720
I received my true dual kit with rear exits yesterday for my 05 extended cab and installed it last night. The install and fit went great. The only issue I had was my front driveshaft is close (not touching though) to the crossover pipe. I'm sure that issue would be resolved with new motor mounts. I was very pleased with the kit and will try to get some sound clips up later today for those of you interested. It's quieter than I expected which was good for me.
