Speed Engineering True Dual Exhaust Prototype..
#732
Thought I'd add some photos of my True Dual kit installed. I had to add two hangers because I had some conflict with a crossmember on my RCSB. Kit fits great besides that little caveat, very solid with the added hangers. I also linked a couple of sound clips. Not the best sound quality, so you may need to turn the volume up a bit. For those of you who may be curious, the truck has an LQ4 with a TSP 228R cam.
Idle:
https://m.youtube.com/watch?v=-mInWs...ature=youtu.be
Rev:
https://m.youtube.com/watch?v=pO_J93...ature=youtu.be
Idle:
Rev:
#734
that goes to the stock muffler
I believe what you are describing in the y pipe kit is from the y to the stock muffler.
#735
What year is your truck?
Idle:
Rev:
Idle:
Rev:
#738
My truck is a '99, the kit rested on my crossmember using the stock exhaust mounts and hangers. I had to cut off the factory hanger to gain vertical clearance and then pull the exhaust up about 1/2 inch with my own hangers. My truck has solid mounts, so it doesn't move the exhaust much if at all, so even though I've only got about 1/4-1/2 inch above and below the exhaust, everything clears after I addressed the contact.
As for the servo, the truck has a Performabuilt Level 2 4L60e in it. I believe he uses Sonnax Super Servos in his transmissions.
#740
looks nice solid mounts will
