Spraying with a t.b spacer
I am sure the idea has crossed a lot of peoples minds, but it looks like a bigger pain in the a$$ than it would be worth. First off the nozzle is designed to go through about an 1/8" thick piece of plastic. Even if you go through the thinnest part of the spacer it will still be much thicker than that so you will probably have to countersink the nozzle to get it to reach far enough into the intake tract. If you want to go the behind the throttle body route, take your spacer off and order the NOS spacer that is designed for it. I saw it in summit for around 179.00 if I'm not mistaken. Good luck whichever route you go. For the record my nozzle works fine in the plastic cold air intake tube.
Originally Posted by inmywhitez
i have the true flow intake and the tube is metal. i should be able to tap into that right?
calsdad
06-14-2023 11:07 PM
