squealing!!!
squealing!!!
finally got my trans problem fixed and now another! seems after driving my truck for about 1/2hr it starts squealing :crazy:
i thought maybe it was coming from the trans/converter so i unbolted the converter from the flex plate and nothing.
also unbolted the stater with no luck, any idea guys :dunno:
here is a vid of the noise, when im driving its about 5x louder then in the vid
noise starts at 1:05
I had a 6.0 with a Whipple come to my shop for the same problem. It was installed incorrectly. Both PCV hoses were eliminated. All the pressure in the engine had nowhere to go. After it was shut off it for forcing it's way out the oil fiter cap. I fixed it by adding PCV hoses to both valve covers.
I had another Ford with the same problem. I found a collapsed PCV hose. The Ford made the noise while running. When I removed the oil cap it stopped. Replaced the PCV hoses and problem solved.
CashDudeHomie
12-12-2009 10:42 PM
charcoal03silvy
30
11-24-2009 02:19 PM
