squeeze anything else in?
#21
How did the header instal go?
Corvette Servo is easy. You have to remove the heat shield which are 2 10mm bolts IIRC. Then use a prybar to push down on the cover and pry off the snap ring with a screw driver. Pull it out piece by piece and replace the parts. I think there are quite a few good stickys on gmfs. Make sure that when you put the cover back on that the snap ring is fully seated.
#22
http://www.gmfullsize.com/forum/showthread.php?t=121944
If you download the video here it shows a good step by step how to remove it and take it apart.
http://www.transgo.com/video.php
#23
i'll to look on gmfs for those sticky's thanks. would def feel better with some step by step instructions.
#28
i remember it rubbing against the trans or trans heat shield. i totally forgot about it until i heard something rattling. the clearance was good everywhere else. nope, bought 4 stainless steel band clamps. the only thing i used was the headers and y itself. used gm gaskets and percey's locking bolts.
