SS baseline dyno numbers, stock
Adkoonerstrator
Originally Posted by 383ss
I would assume 20% for the 4L65E, a few more for the heavy *** 78lb wheels and transfer case.
maybe 22-23%????
what are these rated at stock anyway??? 345? I'd definately say GM underrated again!
maybe 22-23%????
There is no telling about loss with the AWD transfer case. Since its not a true geared case, but relies on fluid pressure to direct torque front / back, it may have more driveline loss than a traditional Tcase. But with the larger dyno numbers we've seen out of the SSs lately, the AWD case may be no hinderance at all.
Definietly the 20s, 4.10s, and the speed limiter held you back.
10 Second Club
Originally Posted by XLR8NSS
What is your MAF reading in lb/min? You can multiply it by ~11.5 to get an estimate of flywheel hp. BTW, that is for stock MAFs and N/A engines.
Adkoonerstrator
we didn't get into the PCM at all. We probably will in a few week when I get edit done. thanks for the info though. I didn't know that
My neck was hurting looking at the graph so I flipped it and tried to bring out the lines a little.
Adkoonerstrator
thank you! that looks much better. I was trying to bring out the lines more, but wasn't having much luck
100 g/s on an unmolested (ie accurately reading MAF) = ~130 FWHP
SOOOOO.... 1 g/s = 1.3 FWHP. Convert to pounds/min is 1.3 / .132 or 9.84848~
So according to Harlan, multiply your MAF pounds by 9.84848 to get your FWHP.
Which is it John?
your method: My 44 pounds MAF would be 506 fwhp (too high) and at 20% loss, thats 405 RWHP. No way.
Harlan: My 44 pounds MAF would be 433 fwhp 346 rwhp at 20% loss. Much more realistic.
Personally, I think that the 20% driveline loss is too high. Well, maybe not for the HEMI, which must have a 25%+ loss.
15% loss of 345 fwhp is 293 rwhp.
single digit dreamer
that would put me at 394hp http://www.neufamily.org/images/efiscreen3.jpg
