SS baseline dyno numbers, stock
Old 01-10-2004, 10:37 PM
Adkoonerstrator
XLR8NSS's Avatar
Originally Posted by 383ss
I would assume 20% for the 4L65E, a few more for the heavy *** 78lb wheels and transfer case.
maybe 22-23%????
what are these rated at stock anyway??? 345? I'd definately say GM underrated again!
What is your MAF reading in lb/min? You can multiply it by ~11.5 to get an estimate of flywheel hp. BTW, that is for stock MAFs and N/A engines.
Old 01-10-2004, 10:40 PM
BigTex's Avatar
There is no telling about loss with the AWD transfer case. Since its not a true geared case, but relies on fluid pressure to direct torque front / back, it may have more driveline loss than a traditional Tcase. But with the larger dyno numbers we've seen out of the SSs lately, the AWD case may be no hinderance at all.
Definietly the 20s, 4.10s, and the speed limiter held you back.
Old 01-10-2004, 10:48 PM
Can't wait to get mine done.
Old 01-10-2004, 10:54 PM
10 Second Club
383ss's Avatar
here's the dyno if you can read it....
http://images.cardomain.com/member_i...88_31_full.jpg
Old 01-10-2004, 10:56 PM
10 Second Club
383ss's Avatar
we didn't get into the PCM at all. We probably will in a few week when I get edit done. thanks for the info though. I didn't know that
Old 01-10-2004, 11:06 PM
Adkoonerstrator
XLR8NSS's Avatar
That is a rough estimate but, seems to work pretty good.
My neck was hurting looking at the graph so I flipped it and tried to bring out the lines a little.
Old 01-10-2004, 11:08 PM
10 Second Club
383ss's Avatar
thank you! that looks much better. I was trying to bring out the lines more, but wasn't having much luck
Old 01-10-2004, 11:10 PM
Adkoonerstrator
XLR8NSS's Avatar
No problem. I hope to have my own SS here soon so that graph is very nice to see.
BigTex's Avatar
Well, Harlan posted this:
100 g/s on an unmolested (ie accurately reading MAF) = ~130 FWHP
You can convert MAF pounds/minute to grams/second by dividing by .132
SOOOOO.... 1 g/s = 1.3 FWHP. Convert to pounds/min is 1.3 / .132 or 9.84848~
So according to Harlan, multiply your MAF pounds by 9.84848 to get your FWHP.
Which is it John?
your method: My 44 pounds MAF would be 506 fwhp (too high) and at 20% loss, thats 405 RWHP. No way.
Harlan: My 44 pounds MAF would be 433 fwhp 346 rwhp at 20% loss. Much more realistic.
Personally, I think that the 20% driveline loss is too high. Well, maybe not for the HEMI, which must have a 25%+ loss.
15% loss of 345 fwhp is 293 rwhp.
Old 01-10-2004, 11:12 PM
single digit dreamer
parish8's Avatar
that would put me at 394hp http://www.neufamily.org/images/efiscreen3.jpg
Quick Reply: SS baseline dyno numbers, stock
