SS Silverado Cam Install
Old 12-20-2003, 03:40 PM
10 Second Truck Club
67SS509's Avatar
Originally Posted by HyperBlackZ
I'm installing a lunati camshaft in it. The specs are:
221/221 .558/.558 114
Do these trucks use the same length pushrods as what the LS1 Camaro/TA's use (7.4")?
Vince
That cam @ that lift you are gonna give up approx. .030" valve lash because of a smaller base circle using the stock lenght push rod. Our trucks use a larger 1.550" base circle. I recommend ordering your cam with a 1.450" base and using Comp's .050" longer than stock rod and maintaining your original geometry. Might make a difference in valve train noise.
Old 12-20-2003, 05:10 PM
BigTex's Avatar
No big deal on the install. If you can do an Fbod, you can do this. Easier to do the springs as well. No need to remove the AC condenser, but the radiator will need to be lifted up and out of the way.
I'm pretty sure you'll need some tuning with a B1 cam.
LCHEE
10-24-2020 04:10 PM
all_individual
10-10-2015 10:09 PM
1bad2k
08-26-2015 07:42 AM
Offroadunleashed
07-20-2015 02:25 PM
all_individual
07-13-2015 11:01 AM
Quick Reply: SS Silverado Cam Install
