which stall????
Old 06-09-2004, 08:54 PM
SimpleManLance's Avatar
do you think the tci 3000 hold up to towing? or get the tt3000 to be safe
Old 06-09-2004, 09:09 PM
Hit Man X's Avatar
TheLadiesMan... how much you plan to tow?
Like F8L said... input torque is the big factor of stall, then comes vehicle weight, compression of the motor, etc.
Old 06-09-2004, 09:27 PM
i dont tow that much at all, if i do it is only two snowmobiles or somthing around that weight.
Old 06-09-2004, 09:29 PM
TigerFan187's Avatar
Default Yank tt3000
say I get the TT3000 and get a shop to do the install what range for the whole deal stall+labor would I be looking at? A geberal range would be cool!
Old 06-09-2004, 10:31 PM
StupidFast's Avatar
Yanks and PI both make great converters. Both will hold up to the power easily.
My old PI converter felt alot looser on the street, it builds alot of fluid heat, and is great as far as performance.
My Yank has a tighter feel, stays around 20 degrees cooler (but still builds alittle heat), and I think the does not have the performance of the PI.
I want a converter that has the throttle response and performance of the Vig but, with the streetability of the Yank.
That is my 2 cents. I have had both converters, at around the same stall.
Old 06-10-2004, 12:31 AM
Hit Man X's Avatar
PI Vig's are typically going to be looser feeling as there is less rotating mass due to being a small diameter unit.
Install will be $250-400 I'd say.
The biggest turn off for me to Yank was them never getting back to me. Maybe it was due to the fact they were moving at the time. Nevertheless I'd have expected some correspondence back considering I was interested in purchasing their product new last year. They only reason I plan to run a TT3K is due to the fact it's used and about 2 hrs from me...
FWIW...
Old 06-10-2004, 05:42 AM
Cuz I AM a BADMOFO
BADMOFO's Avatar
I love my Yank. Let's face it, usually, you get what you pay for.
Old 06-10-2004, 08:24 AM
greentahoe's Avatar
Its going to depend on what you believe to be the better unit. The PI Vig's give you one free re-stall. I dont know if Yank does or even can re-stall. I love mine. I dont know if it is tight or loose since I dont recall driving anything else with a stall.
wickedRCSB
10-30-2015 09:45 PM
Miguel199
10-16-2015 08:04 PM
Wolftrk99
10-02-2015 08:17 AM
bisqikss
09-27-2015 09:40 PM
sTNT971
09-26-2015 06:27 AM
Quick Reply: which stall????
