Starting Issues
Starting Issues
Lastnight I went to go pump gas because I had a little bit under a quarter tank when I finished filling it up, my truck wouldnt start this is the second time it does this to me at the same gas staion damm Shell V-Power. Anyways first thing that comes to mind is fuel pump I turn the key and wait for the littel noise and its there still thinking it is my fule pump I give the gas tank a few kicks and went to start again and nothing. I then go under the truck and check the O2 sensors they seem fine i move the wires around and go to start up and it started up just fine. So now im Im thinking I have a bad o2 sensor. No Check Engine light by the way. Any ideas guys the truck turn on fine now but I just dont want to be left at a gas station next time I pump gas.
PT's Slowest Truck
I'd get underneath there and re-check all the wires, considering you just swapped your trans you may have disturbed something or left something loose. Did this problem happen before the trans swap, and does the truck crank, or do you get nothing when you turn the key?
I have listened to it and it sounds the same as usual I have always had the habbit of turning the key untill it primes all the way and then crank it to start.
zblee
63
06-10-2023 01:25 PM
97aztecgt
08-13-2015 02:11 PM
05GMC4.8
08-07-2015 09:55 PM
cams 98 silverado
07-31-2015 07:36 AM
