Steering shaft hitting Pacesetter headers
Anyone else have this problem. Did a search and got a lot of these problems when it came to Thorleys. Here's a pic. First plan was to dremel the end of the bolt off with the backup plan to moving the steering box and getting an alignment. Thoughts?
![](http://bertok.us/agreif/posthelp/01_drivers_h_s.jpg)
Mine were fine gettin past the shaft and aren't hitting when I turn the only problem I had putting the in was the trans and the trans lines had to remove the trans support and move the trans and engine over about 2" on mounts to fit between the frame.
