Steering shaft hitting Pacesetter headers
Old 06-16-2006, 08:25 PM
Easy:
Turn the steering wheel so the bolt is not side to side. Facing top to bottom. Reverse the bolt and put it in through the other side. That should do the trick.
Old 06-16-2006, 10:19 PM
Zick's Avatar
Originally Posted by Order 66
Easy:
Wouldn't that just cause it to hit again once he made a full turn of the steering wheel?
Old 06-16-2006, 10:51 PM
RoninsDenali's Avatar
Heh that would be a problem now wouldnt it...
Old 06-16-2006, 10:59 PM
blksilverado's Avatar
thats weird. didn't have that prob when i put mine in. must be the location of the steering box. i would try a shorter bolt.
Old 06-17-2006, 12:07 AM
nonnieselman's Avatar
You guys are silly... Flipping the bolt wont do any good unless he never turns.. LOL
I would cut the bolt close as possible to the the nut and install it with some loktite.. and see where that puts you.. or if you need just a hair more.. grind the head of the bolt off a little, and then grind the nut down some?? but dont get to crazy.
Let us know..
Old 06-17-2006, 05:06 AM
SimpleManLance's Avatar
mine hits too.. but im not sure if it is the bolt or the shaft. i cant remember. i i know is when i go slow around a corner and give it some gas to put torque on the motor it hits. i will give you more details on mine later today.
Old 06-17-2006, 06:40 AM
PT's Slowest Truck
budhayes3's Avatar
If cutting the bolt doesn't help, shifting the gear box might. I had the same problem when I originally installed my Gibson shorties (funny how my shorties hit, but my SW longtubes clear with no problem). Anyway, I unbolted the steering gear box and shifted it a little bit. When I was done, you could actually see that the steering shaft turned truer (tighter circle when turning). After that, I had a ton of clearance, just had to align it, as moving the gear box will effect the toe adjustment.
Old 06-17-2006, 11:39 AM
Colby 04's Avatar
beat me to it
Old 06-19-2006, 02:23 PM
agreif's Avatar
[QUOTE=budhayes3]If cutting the bolt doesn't help, shifting the gear box might. I had the same problem .....QUOTE]
Yep, you are where I got the idea from.
Old 06-19-2006, 02:30 PM
white1's Avatar
BFH
Quick Reply: Steering shaft hitting Pacesetter headers
