Steps to reduce pyrometer reading when towing???
Originally Posted by 4.8T
ok found it autometer says after the turbo if applicable if not the 4" from header flange.
well thats just what autometer says. so when i do mine thats where i will put it.
Originally Posted by Wilde Racing
I have alwas worryed about my exhaust temps too, but me being turboed is a little different from SC when exhaust temps are being compared. Anyway with the 5.3 I seen exhaust temps hit 1400 with out towing but up a hill. now with the 6.0 the exhaust temp gauge goes up almost as fast as the boost gauge, My only guess is the 5.3 cats with 88,000 miles don't like the 6.0, so what year is you truck blowndenalixl? could exhaust restriction be a probplem?
How do I change this text
have you tried gutting your cats or replacing them? it makes sence for this to couse high temps if you consider that when you look at bigger exhaust systems for desiel trucks they always say "lower your egt by ....." unless there full of it but it make since
I when to the shop that has done all my exhaust work, he would not do it because of Emsions (sp). I will have to have it done in a nother county.
Well this Friday I am going to have a chance to go to the a Supercharging expert in Calgary, Steve Eisenberg of Davenport Motorsports, and have the A/F looked at. Hope that will me know how things are.
Towed home the trailer from the lake today. Ran mostly 1300 to 1400, but when uphill around 1600 or so. Will be interested to see what the verdict is on my tune. Might have to pull the Wester tune, put in my Superchips tune, and have them mod it there.
2nd veh now with a Supercharger and heat problems. Duramax starting to look very attractive. 1 chip = 800 ft-lbs torque. Hmmmmm.
Thanks
D
Thanks
D
Really laying off the throttle is best. You're asking too much from it, it's the catalytic converters that will go first. Towing is more of a demand on an engine that a quick WOT blast down a dragstrip. For example, the reason the LQ4 in 2500 trucks has no Power Enrich mode in the stock programming is so that they can sustain long periods of open throttle without overheating the exhaust and converters. Same goes for the last two generations of bigblocks - they are tuned for towing. Superchargers are tuned for performance but you have to regulate it yourself. Generally you don't want to pull much more power up a grade than the engine would have in stock form.
Without seeing any raw data from your truck I would probably start by looking at timing advance.
gaps
10-15-2015 02:53 PM
Superman09
09-25-2015 05:55 AM
