Still have my low RPM ping!!!!!!!!!!!!
Old 04-28-2004, 05:35 PM
99Silver6.0's Avatar
Default Still have my low RPM ping!!!!!!!!!!!!
After 2 cans of seafoam. Earlier today I heard that dam pinging again. Its really pissing me off too!! Anybody have any ideas? Cause I am officialy stumped!
Old 04-28-2004, 07:38 PM
bad fuel??
Old 04-28-2004, 07:50 PM
99 Blue Z71's Avatar
i got some bad gas this time and my truck pings when I get on it. try runnin some octain booster or a higher octain through it one time....that cured mine when I was runnin 87 and b4 the westers tune.
Old 04-28-2004, 08:07 PM
OBXMarine's Avatar
Replace the PCV valve. Maybe run a can of Techron in the fuel tank too. It helped a bit for mine. You may also consider replacing the EGR Valve.
Old 04-28-2004, 08:41 PM
PCV is the new fixed orifice. Im running Amoco/BP 92 and I have been for a long while. I have no clue what the problem might be.
Old 04-28-2004, 11:04 PM
Performance Trucks Sponsor
FarmTruc's Avatar
I see this quite a bit when a truck or car comes into the shop, I update gm's calibration (flashing the pcm) and that usually takes care of it.
This will probably mess up your edit , so instead you may want to find a new cal with the same segment and load that into your pcm.
later,
allen
Old 04-28-2004, 11:09 PM
BigTex's Avatar
Did you remove your EGR system (or alter the pipes)?
Your best bet is to get a PCM from a newer truck than your 99 model. The 99s are horrible about knock, ping, and sluggish performance. You'll find that even with doing everything in Edit, the 99 tunes aren't as good as newer ones. But like Allen said, that may mess with your LS1 Edit locked cable.
Old 04-28-2004, 11:47 PM
Hit Man X's Avatar
From what I recall, Jared's got a '01 spark table in there (no advance) and has the resistors soldered into the knock sensors.
Do knock sensors go bad?
Old 04-28-2004, 11:48 PM
bigguy75inches's Avatar
Its your rings,, your rings are blown, your motor puked its guts out. Well i hope not! hahah mine sure did though! lol oh well... its just bad gas
Old 04-29-2004, 08:49 AM
01Blackerado's Avatar
You might want to check the settings on your edit programm and make sure that you didn't advance your timing too far.
Quick Reply: Still have my low RPM ping!!!!!!!!!!!!
