Stock fuel lines and return question
Old 01-02-2005, 12:24 AM
SimpleManLance's Avatar
Originally Posted by parish8
not really sure. i think the twin set up would be better. if the 420 will flow as much fuel as twin 340m's then you will have a return line problem and too much fuel presure at idle. my set up works because the 2nd pump is staged. comes up at 4psi of boost.
how do you get the second pump to turn on at 4psi? are you doing it through ls1 edit?
Old 01-02-2005, 12:33 AM
single digit dreamer
parish8's Avatar
no, it is just a presure switch. there is a conector up near the fuse box under the hood that you can plug into to turn on the 2nd pump. on my truck it goes to a hops switch but you could turn it on anyway you want.
Old 01-02-2005, 09:13 AM
BigTex's Avatar
Ahhhh, I see. Similar to a boost a pump that increases voltage under boost. Under boost, this switch trips the second pump. Good idea.
5.3Okasai
03-09-2022 01:07 PM
chopperloco
07-10-2016 10:45 PM
lxcoupe
07-21-2015 02:12 AM
76k10chase
07-17-2015 01:48 PM
4B11T
07-13-2015 03:48 PM
Quick Reply: Stock fuel lines and return question
