stock intake mainifold=crap
Old 08-23-2010, 01:43 PM
LightFighter's Avatar
I think I'm gonna drop the LS1 from my vette in my truck.... once I get my LS3 Stroker done for the Vette...
Old 08-23-2010, 01:53 PM
06Sierra2's Avatar
Originally Posted by Quik
why is he saying its crap? what was the KPA drop youre seeing?
he didnt say it was crap. he just said i had a restriction somewhere. i dont think its exhaust with lt headers and cutout. thats why we were thinking intake manifold? based on what everyone else says tho idk. i always heard the truck intake was good. i was 88 at idle and 85 wot. does that sound right?
Old 08-23-2010, 01:57 PM
06Sierra2's Avatar
Originally Posted by LightFighter
if your going to go with a power adder in the future doing over do it with the gears
i plan on staying na for now. maybe a small shot of spray in the future tho
Old 08-23-2010, 02:28 PM
5 year bitches!
Quik's Avatar
Kpa tells story. If Kpa Is dropping then you have restrictions somewhere.
Old 08-23-2010, 02:36 PM
JoeyGC5's Avatar
the higher the kpa # is towards 105, the more equal you are to atmosphere. So those #'s aren't correct for idle, by no means. Normally you might see 40-65kpa at idle, depending on the cam/induction setup, and 90-105kpa at wot depending on homw bad the intake restriction is.
For example my 416ci vette with port matched L76 intake has never been over 97kpa at wot (longtubes, 3" x-pipe, and cutouts for exhaust). But I still make well over 500rwhp and my idle is right around 55kpa at 800rpm with a fairly large duration hyd rolller cam.
Old 08-26-2010, 12:14 AM
mcamarols1's Avatar
I was working on his truck and the KPAs with the key in the run position without the truck running are at 88KPA, we are in El Paso and the DA can get into the 8000s at times. The reason I think there is a restriction is; at WOT from about 3500rpm KPA drops from 88 down to 86 then near redline (6300) its at 85. He runs a K&N CAI, I doubt that is the restriction, truck MAFs are 85mm so I doubt its there, however the TB and manifold are stock. I said I thought it was the intake, but you truck guys here are going against my logic. So maybe its the TB. I know that in my car I see a drop of about 1-2 KPA at 6500 and thats through a 85mm lid, 85mm maf, a 95mm TB, and a 92 ported FAST with the TB opening ported to 95mm. I was expecting a drop in KPA, but not that much. What do you guys think?
Old 08-26-2010, 12:48 AM
SincalT/A's Avatar
That drop in kpa is not enough to warrant manifold change.What do the iat's look like through the run? Meanig is there much of a temp change?
Old 08-26-2010, 06:12 AM
5 year bitches!
Quik's Avatar
3kpa does show a restriction of some sort, however that is still low amount of kpa. whats exhaust look like
Old 08-26-2010, 09:44 AM
hirdlej's Avatar
I was seeing as much as a 5kpa flutter at 5200rpm+ with my 6.0L, cam, 90mm intake and little 1 5/8" OBX's with the 3" catback. I haven't checked it in a few months after putting the 1 7/8" headers with true duals. The truck runs much better up top though.
shawn96gmc
05-17-2016 04:15 PM
TA63
03-29-2016 04:38 PM
The_W
10-28-2015 09:00 PM
Ketis
07-23-2015 12:37 PM
4B11T
07-13-2015 03:48 PM
Quick Reply: stock intake mainifold=crap
