Stock LS3 cam too big for stock LM7?
Newb here. Got an 05 Avalanche that ate a lifter and the cam is no beuno. I've got a buddy that has a stock LS3 cam that he said I could have.
LS3 cam specs 204/211 .551/.525 117lsa
LM7 specs? Not 100% sure on these specs? 190/191 .466/.457 114lsa
I'm mostly concerned about the lift on the cam. Guess I could throw some springs at it too since that will be easy with the heads off. LS6 springs?
Appreciate any advice. Cory
Baltimore Whore
Its all in how you look at it.. Your truck ,may not be slow, but the ls6 cam is not the best cam in the world. Yes it works good, but for the price of a new one, you can find ones that perform better in the same price range..
I thought about picking up a used LS6 cam and try running it advanced, but then I'm like, "Hey, I could buy a small cam, run it straight up with a new timing chain, and not have to mess with a new timing set, and it will give better results."
