Are the stock main bolts reusable?
FormerVendor
https://www.performancetrucks.net/fo...d.php?t=360704
some say they arent TTY and some say they are. Most upgrade to the ARP studs
After reading that i would probably just throw in the ARP's
True, once you buy the ARPs then you can reuse those if you needed to.
edit.
I saw the other thread, ARPs would not be a wise investment in that case.
edit.
Originally Posted by thunder550
I'm pulling the main caps to check for bearing failure, can I reuse the stock main bolts and studs?
I talked to a guy here that builds a good amount of gen III engines and he has seen alot of the main bolts breaking.... I havent seen any at the stealership, but I bought new ones for my 6.0
bbowerman
07-26-2015 10:57 PM
