stock ss performance?
#21
Originally Posted by 427
I have not broke the 4L65 yet! Left the line at 15psi yesterday and it seemed like something should have broke! It seems to spin the front tires worse than the rears but its still moving out for such a heavy truck. Can't wait till the track opens to get some time slips.
Kurt
Kurt
How far are you from metro airport? I'll race you
#22
Blue truck is customers, it has 402 ci forged crank rods pistons.(this is the one I did the 15 psi launch in)
If the 4L65E (and the Tcase) is taking that much power, thats very good news.
#23
Originally Posted by OOsilverado
Ive still got some tuning issues because I havent got a wideband yet, and my fuel pump took a crap. But my best so far is 13.5 @ 96 MPH with a 1.92 60'
I know Ive left a lot of power on the table with my tuning and fuel issues but that will change soon with the new pump, roller rockers, and long tubes about to go on. And then really dial it in with a wideband.
Honestly, I didnt feel a difference at all with the fans, I felt a difference when I had them on my 2000 but didnt feel it on this truck.
The blow off valve didnt give me any performance, but it does make a lot of noise. It scares the **** out of people when they hear this loud blow off valve coming from this big truck.
The 4L80 conversion will take a little bit of work, but it shouldnt be too bad. Someone is gonna have to make either a custom output shaft for the trans or a custom input shaft for the t-case. I wouldnt mind doing something like that when it comes time for me to do my trans.
just thought you might want to know this. my father & i just bought a couple of stall convertors from tci here in bossier & I had them install both of them. my father has an 03 ss lq9 with a p1sc @10psi, comp ls1 xr265hr-14 212/218@.05 with .522/.529., jba headers & 3inch exhast with ed write programming & tci 5x 3000 stall. anyway they told us that they make an adapter for the 4l80e install. we did not get the specifics because i am hoping the 4l65e holds up a little better than my 4l60e (8100 miles 2/4 band burnt)(thank god i work at a chevy dealership). I was dissipointed that his 4l65e had the same servos as the 4l60e. when you said that you are leaving alot on the table with programming how much? we had ed write in oklahoma do ours & i was thinking of getting ls1 edit but for the money is it worth it?
#24
I think it would take about 40 minutes to get to airport from here. Let me know a time and place and I will meet you, sounds like fun. Give me a phone number and name.
Kurt
#25
it's on!
Im at 696 and I75, I will meet you at "Thunder Road"....Sorry had to go there.
Kurt
Kurt
I'm at 275 & 94
What are you gonna race me with? I'll pm you later... This is cool normaly everyone on here is too far away to be able to talk smack with and to get a race going. :o)
#26
I'm at 275 & 94
Kurt
#28
I will bring a 2003 blue SS Silverado. I seen in your sig you ran your truck on a g-tech pro, any chance of a ride with that on board my truck? I would kill to get a et on this truck.
Kurt
Kurt
no problem You can make a pass with the g tech
#30
I dont know how much my tuning is holding me back, but it feels like a considerable amount.
If you have a custom tune done, you should be pretty close to where you need to be at. LS1 edit is great and if you plan on doing more mods then its probably worth buying. But the only way to see if you can try to squeeze more power out with the tune would be to hook up a scanner and a wideband if possible and log some data to see where you are at.
