STS Featured in Sport Truck and Turbo Mags
Originally Posted by GMCtrk
those numbers aren't too impressive, although they were only doing 5.6#.
with them a.i.t.'s, they can't turn the boost up much more with any effectiveness.
I still wanna see someone fab up a Duramax IC to one of these things. I migth have to try it.
Originally Posted by F8L Z71
True, but that's why they sell Meth kits.
I'll bet you could get rid of the meth all together.
Would there be any room for an air/water intercooler back close to the turbo?
Originally Posted by Black Blown 02
I think you should, I'll bet you'd be impressed with the results.
There is plenty of room. Only thing I fear with an IC back there is mud and such cloggin it up, but I have thought about it just because it would ve very simple to plumb inline. As for the Meth I would most definately keep it. Mainly because if I could get close to 100deg IATs with just an IC then spray the meth and I would get 60deg or better IATs. If you look at cars the run meth as gas their intake manifolds actually freeze from being so cold, well not freeze but run very cold. Plus I need the added octane/fuel with using such small injectors and stock pump
What duty cycle are those injectors at?
Ahh, I didn't wanna do the air/water just because of more plumbing issues. I just wanted a simple air/air setup Plus money is a concern now.
Not sure what the duty cycle is at on them right now. I have yet to get any data logs on it since it's been in the shop awaiting the insurance guy to cut me a check. I'll ask Rick to give me all those details if it hits the dyno today. My tuner is real big on making sure the injectors are running low duty cycles and advocates using 30lb injecotrs on even small bolt-on LS1s so I'm sure he is tracking all that.
My ATAP doesn't wanna work and I can't afford EFILive yet.
i was thinking that one mounted between the box side and the frame with a fan blowing on it like the remote mounted transmission coolers use would work out well and keep it clean. you could also only have to run the fan when the a.i.t.'s get up high.
how does this turbo system compare to say the cmotorsports one with the traditional mounting?
Ease of install, huge difference.
