STS and low/no oil pressure
On the STS kits, has anyone had problems getting oil to the turbo if the motor is running with very little or no oil pressure?
Just regarding the placement of the oil line tap on the engine.
sts kit comes with a booster pump for the turbo... Also you wouldn't want to run your engin if your getting little to no oil pressure, if you do say bye bye engine even under no load situations
69z-28
09-21-2015 07:31 AM
