STS #'s
Old 08-03-2004 | 09:48 PM
03sierraslt's Avatar
The more and more i hear about the sts setup the more i like it. What psi do the standard kits come set up to run? 5?
Old 08-04-2004 | 04:33 AM
therock's Avatar
Default You need to talk to a STS dealer
Call nelsonperformance.com. He is a dealer and has a dyno too.
Old 08-04-2004 | 05:43 AM
derek_silvy's Avatar
I hate to come in here and be like this, but this costs what, 4 grand
People can put out as little as 320 and as much as 350?
A 5.3 with intake/exhaust/headers/cam seem to be putting down about 300 horses. All of which can be done for $1250 if you play your cards correctly.
Then bore, and stroke to get some more displacement, for, I figure $1400. Get some good heads for 1500, and some bigger injectors for 200. So, for a couple hundred more than a turbo or s/c, you will see much bigger numbers than 320-350 IMO.
Thanks,
Derek
Old 08-04-2004 | 10:33 AM
F8L Z71's Avatar
I think you are failing to se the logic behind the turbo. A heads/cam truck will never see the low to mid range power #s that a turbo'd or Radix'd truck will. These are also very low boost #s. I don't know many people that will stay with 5psi.
Show me a head/cammed/stroked 5.3L that makes this kind of HP throughout the rpm range:
I understand what you are getting at but you're talking alot of mods to get 350rwhp, mods that will negatively effect drivability and smogability. The STS kit is on the verge of getting a CARB # and if that's the case you could easily bolt up a kit and be smog legal and great drivability something a fully whacked out head/cam/stroked/bolt-on truck simply can't do.
I went through 3 sets of heads/cam and even a lil nitrous on my T/A and did the whole supercharged then stroked & supercharged thing on my Mustang and i have to say that the forced induction route was always the funnest.
Old 08-04-2004 | 10:42 AM
Hmm after doing some reasearch and listening to the threads this looks like i may be adding this setup to my AV.
Stock 5.3 seems to hold up to just the 5psi and one can upgrade injectors,tune, and maybe Alky injection and go up higher with the boost. Might be looking for this real soon.
Bonedog
Old 08-04-2004 | 12:00 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by Bonedog
I would put it back correct?? I think my rig would be way too loud with a muffler. I set alarms off now with me FM40 on it.
My SSS sounds like a nice aftermarket kit with the STS GT67 and no muffler. I also am using a 12" tail pipe
Wide open, its pretty loud, though.
nabozny21
10-17-2015 07:47 PM
jeff.ellis
08-18-2015 10:34 PM
ZO6Ted
08-12-2015 07:50 PM
Deceptarado
07-08-2015 05:24 PM
chris99gmc
17
12-04-2004 05:50 PM
Quick Reply: STS #'s
