STS turbo plus fuel problem
Old 01-17-2005, 10:16 PM
Default STS turbo plus fuel problem
Installed sts turbo, 43lb injectors,Walbro intank pump and won't rev past 5000 rpm? sounds like rev limitor from 1-2 shift, then 4500 rpm from 2-3 shift sounds like rev limitor. Checked fuel pressure at idle 63lbs. wot drops to 49? any ideas please.
Old 01-17-2005, 10:23 PM
LS1TECH Sponsor
badpewter-z's Avatar
stupid question but has it been tuned yet?
Old 01-17-2005, 10:25 PM
blownerator
BlownChevy's Avatar
Sounds like your in tank pump was not installed properly. I would drop the tank and verify the pump and FPR are seated correctly.
Yes it was tuned by Allen Nelson
Old 01-17-2005, 10:27 PM
I guess I should start there as the fuel line came off the first time around then we put two clamps on it?
Old 01-17-2005, 10:32 PM
blownerator
BlownChevy's Avatar
Yeah it might be the place to start. Make sure everything is perfect. I know it is a pain in the a$$ but you need to make sure.
Old 01-17-2005, 10:49 PM
I had my mechanic do the fuel pump, could you tell me what to look for if I decide to take a look myself.
5.3Okasai
03-09-2022 01:07 PM
lxcoupe
07-21-2015 02:12 AM
Mossyoakglock
07-17-2015 08:30 AM
Deceptarado
07-08-2015 05:24 PM
Quick Reply: STS turbo plus fuel problem
