Stupid Fan question
I know this topic has been covered but couldn't find all the answers.
I have a set of LS1 fans and a harness for them just sitting around uninstalled.
I saw a the 05+ setup in a truck today and it looks so much nicer then what I am looking at doing. So my questions are:
1. All i need is the 05+ fans and radiator
2. P/N for both?
3. will my ls1 fan harness work?
4. do I need any additional supports or anything?
5. will all hoses match up?
2. P/N for both?
PT's Slowest Truck
All you need are the fans, radiator, harness and pcm tuning to turn them on. Your LS1 harness will work, but the connectors will be different, so you'll need to splice those in. No additional supports, but you'll need two bolts like the ones that are holding your current radiator in to bolt the fans in (can't remember what size bolts, and don't have part numbers, sorry.) Hoses all line up
![Thumb](https://www.performancetrucks.net/forums/images/smilies2/thumb.gif)
2. P/N for both?
2. P/N for both?
2)Why, not getting thru a yard? it'd be cheaper than a dealer, plus they'll be fine.
3)IDK, maybe, maybe not; some others may chime in.
4)No. They use the holes that are in existing core support. My bolts that support wider rad & are needed, I got from yard.
5)Y
I see BH3 beat me to it. For once, he'll be able to beat me.
![Tongue](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_tongue.gif)
PT's Slowest Truck
https://www.performancetrucks.net/fo...d.php?t=470850
