Sudden oil pressure loss while driving
What’s up guys. Good really use your helpful knowledge on where to start figure out this issue.
Well go do my weekly gas fill up on my Silverado SS so check all my fluids as always and everything good. Oil change was due for next weekend. So I was on my way to work cruising a steady 70 mph, I did accelerate to pass up a slower car but nothing aggressive. Right after that my warning alarm goes off indicating low oil pressure and it’s pumping at 10. Pull over immediately. Turn engine of and on and stays at 10 on idle and when I rev it up I get to about 35 max. Could probably do more but didn’t want to over rev it. Truck has stock lq9 with 180k miles. Never had oil pressure issues always idled at 40 and 50 under throttle.
What could be the sudden cause of this. Bad oil pump? Appreciate any help. Thanks
Verify pressure with a manual gauge first.
At this point you don't know if it's a real issue or if there is an issue with the sensor itself. If the gauge matches the sensor/cluster then you are digging into it deeper.
Could be a failed oil pump o-ring, oil pump itself or possible issue with a cam bearing or worse.
The following 2 users liked this post by swathdiver:
darkirish63 (08-28-2020),
FrankU (08-29-2020)
First verify that you actually have an oil pressure problem, not a gauge problem.
Is the engine in typical low OP distress? you know, ticking lifters, lots of scraping and straining mechanical noise, bad smell coming out of the crankcase, oil is burnt, metal chips or glitter or fine powder in the oil? If not, you probably have a gauge malfunction, not a pressure one.
I have a raw truck pan here. I can measure the water it takes to fill the pan. Prob need 1.5-2" more fluid on top of that to get to the o-ring
but, 2 more quarts is also more volume pushing into the pickup as well as being sucked in
could overfill and park on an incline, might help reduce the amount of oil you need to use to test this
submerge the o-ring?
Not a "repair"; just a troubleshooting technique. IMO anyway. If I did it and found that it made a difference, I wouldn't drive the truck until I'd fixed it. But that's just me.
Note also that if the pickup has failed THAT BAD, the oil will be foamy or bubbly on the dipstick when running, due to all the air getting mixed into it. If it's not, chances are it's not a pickup problem.
Richard
swathdiver (08-30-2020)
YenkoChevelle69
11
02-04-2009 07:38 PM
blkssncpt
22
08-02-2007 11:29 AM
