Supercharged daily driver's......
Old 05-27-2005, 02:06 PM
12 Second Club
O3GMC's Avatar
I was also considering 4.10, as my friend would pretty much install his old ones in my truck for free, but I have plenty of low end, and can spin my 305 dr's with ease, what I lack is top end, and it sounds like 4.10's wont help much there....I also do 90% freeway driving.
Old 05-27-2005, 02:34 PM
Mr. Sandog's Avatar
You would lose top end with the 4.10's, as well as traction, so you're definitely good with the 3.73's.
Old 05-27-2005, 05:01 PM
what a rush!
moregrip's Avatar
Originally Posted by Naked AV
I liked the way my truck kicked down to 3rd or 2nd from 4th a lot better with the 3.73's. There is actually less power when doing this with the 4.10's.
thats what your downshift tuning tables are for
get busy and quit complaining
Old 05-27-2005, 05:41 PM
8 Second Club
samdogmx's Avatar
you should also take into consideration, wut size tires your running
us 4x4 guys can use more gear since we have taller tires.
Old 05-27-2005, 05:48 PM
slowride_3's Avatar
Default gears
I am in the process of installing 4.10's in my truck I run 285 50 20's do you think I will lose alot of top end power?
Old 05-27-2005, 06:00 PM
11 Second Truck Club
Breeze's Avatar
I love my 3.90s, but I think Ill like them even more when I get a lil taller tire. For those guys with the lowered short beds I think 3.73s would be plenty. I dont think you lose any top end because it puts you in higher rpm,s I think it can give you more top end.
Old 05-27-2005, 06:05 PM
Mr. Sandog's Avatar
You miss the point, but that's okay.
Old 05-27-2005, 06:26 PM
03sierraslt's Avatar
I am also running 4.10 and dont have a problem with them, I think i would take 3.73 if I had a choice.
Old 05-27-2005, 09:11 PM
white1's Avatar
Slowride. You'll be fine with 4.10. That tire is about the same as a 265/75-16 which is what the Z-71's come with, I have 3.73's in my Z, and wish I had the 4.10. I plan to get some 20's and run that same size tire.
12 second. Todd, Just leave your 3.90's in there. how much do you drive on I-10 anyway? If you had front 3.90's too I'd swap.
Old 05-27-2005, 09:30 PM
jmproductions's Avatar
Seems like a lot of confusing stuff here. I went from 3.73's to 4.10's and the truck accelerates faster, period. You will not lose top end power. Maybe some top speed if you have enough engine to tach out OD, but you guys shouldn't be trying to go that fast anyway, these are trucks.. HE HE. Some people think that they have lost power because their truck won't downshift into 2nd anymore at a certain speed. Yes, it will lower your shiftpoints but you will reach your powerband faster and more often getting to the same mph with lower gears. The result is lower ET. Now all that being said if I had an automatic and I drove the truck daily I would stick with the 3.73.
Quick Reply: Supercharged daily driver's......
