supercharger and meth kit ?
Old 07-15-2005, 01:32 PM
2500HD6.0's Avatar
I haven't put the charger on yet I just got it but I was going to just let Allen do it all at once so when I put a smaller pulley on I woulden't have to go back to see him to get retuned. Also how much did your 44# help you power wise? I have 33# but looking to get 44# if I can run more boost and the charger came with a tune but I all ready had one from Allen.
Old 07-15-2005, 01:58 PM
Mort's Avatar
Cool
I am just now installing my meth injection so I should have an idea of how it is working for my system soon. I think it is a good idea for your system as well and should let you run over 10 psi but it would be best to get confirmation on that from a radix user who has tried it first. Don't forget to move the IAT Sensor after the injector in the intake so you will have a good idea of the actual temps your engine is seeing with the meth.
I went with the 44# injectors and an in-line 255L fuel pump because they were recommended by other FI enthusiasts and by my tuner. I am not sure when 33# injectors will run out of capacity or if they will but I am sure Allen will be able to help you out with that and get you set up. I have heard of a 2 3/4" pulley but not sure if it is available for the side mount charger but I am sure that Allen will know. Allen or EBAY would be a good source for a smaller pulley. I know the 6.0 can run a smaller pulley than the 5.3 to get the same boost levels.
Old 07-15-2005, 03:54 PM
2500HD6.0's Avatar
thanks for the info. and heres Jerry's meth kit set up on his sts kit it might help you http://forum.ls1truck.com/index.php?showtopic=3967
Old 07-15-2005, 04:28 PM
2500HD6.0's Avatar
Has any one delt with Pulley Boys before? I just got of the phone with them and they said that they would fab any size pulley that I wanted what size should I go with if 3'' is stock with 5 pis and I want to run 7 to 8 pis?
2500ZL1
01-25-2016 06:30 AM
Silveradorst07
12-31-2015 12:04 AM
greedygenius
09-03-2015 06:51 AM
WICK3DxGATA
08-31-2015 07:21 AM
Deceptarado
07-08-2015 05:24 PM
Quick Reply: supercharger and meth kit ?
