surging at idle on 2000 tahoe please help
Old 04-22-2003 | 03:20 PM
redaddiction's Avatar
Default surging at idle on 2000 tahoe please help
Hey guys i have a problem my dad's tahoe will sit and idle and will drop to like 200 rpms and nearly die it is drive by wire and there is a whining coming from what we think is the fuel pump do you think the fuel pump is going out?
marc
Old 04-22-2003 | 03:43 PM
ryan99chev's Avatar
Default Re: surging at idle on 2000 tahoe please help
That was happining to my 99 truck. It was the fuel pump. I put a gauge on the fuel line and it was getting 42 psi at an idle but when you gave it has it dropped all the way down to 11 psi. So i would say check that out to see if yours is doing the same thing.
<small>[ April 22, 2003, 02:44 PM: Message edited by: ryan99chev ]</small>
Old 04-22-2003 | 03:48 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
My aunt's does the same thing (except her's doesn't whine). That thing runs like a POS now too. When it was new it would spank V6 Mustangs. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Now it can't get out of it's own way.
Try changing fuel filters first & see if that helps. Hmm...I wonder if my aunt has?
Old 04-22-2003 | 04:00 PM
pewterZ71's Avatar
yup mine just finished doing the same thing, if u replace the fuel pump which is probably the problem chech the wiring, mine were melted and stuck together on the INSIDE of the tank
Old 04-22-2003 | 04:08 PM
ryan99chev's Avatar
I put this fuel pump in my truck GRN-GM722-2. That is summits part number for it. It is a 255 lph fuel pump for the ls1. I had to do a slight mod to the fuel pump assembly but it wasn't anything. I stock one from gm was like $398. I paid under $150 shipped 2nd air. It fixed mine.
JCW
09-22-2015 04:59 PM
smokeshow
08-23-2015 09:23 PM
fillpot
07-26-2015 08:21 PM
Breitling
07-06-2015 07:39 PM
Breitling
07-06-2015 05:50 PM
