Swapped Stock Air Box Out - Good Results
Old 10-05-2004 | 12:11 PM
nativetexan's Avatar
13 Second Truck Club
Default Swapped Stock Air Box Out - Good Results
Intake setup before the swap:
AirAid intake tube
Stock Air Box
K&N Filter to fit above
G-Tech 0-60 time: Typical time 7.20 seconds. Best time 6.94 seconds.
AirAid intake tube
K&N style cold air setup off Ebay. Tossed the filter.
K&N Filter model RF-1020
G-Tech 0-60 time: 1st run 7.20 seconds (shifting) with tire spin and into the rev limiter. 2nd run 6.90 seconds with tire spin. 3rd run 6.67 seconds. 4th run 6.76 seconds. I just let the tranny shift on its on after the first run.
Needless to say I'm happy and a little surprised at the results. I would have thought a tenth maybe. The ol' butt dyno is giving good results too. The truck seems more responsive on the low end and the tone of the intake noise is better. It sounds less laborous, if that makes any sense. I hope to get back to MTI next week to get the rev limit raised to 6200 or so and the 1-2 and 2-3 shifts raised to near 6000. I also want to get it on the dyno again and see what numbers we have now.
Old 10-13-2004 | 03:34 PM
MTI tweaked the tune today for the new K&N filter setup and here are the numbers:
Stock tune with K&N Filter in stock box and AirAid Intake Tube:
272 HP and 293 ft/lbs
MTI tune with K&N Filter in stock box and AirAid Intake Tube:
278 HP and 302 ft/lbs.
New MTI tune with new K&N Filter in Ebay heat shield and AirAid Intake Tube:
297 HP and 317 ft/lbs.
Old 10-13-2004 | 04:06 PM
FILE's Avatar
Nice gains. What happened to the first tune. I would expect to see more out of a custom tune.
Old 10-13-2004 | 05:10 PM
I am not sure. I have read that the typical gain for LS1 F-Body cars is about 10HP & 10 Ft/Lbs torque. My numbers were right in line with that on the first tune. MTI recommended a better intake. I didn't like the numbers from the 1st tune either, so I decided to try a new intake system and let them tweak it. It looks like it made a difference.
The temp today was 78 deg which is about 5 deg cooler than the base numbers and the humidity is about the same at 75% or so.
mzoomora
01-03-2016 07:06 AM
Ketis
07-23-2015 12:37 PM
blownss27
07-20-2015 08:59 AM
00pooterSS
07-16-2015 03:03 PM
00pooterSS
07-16-2015 02:41 PM
Quick Reply: Swapped Stock Air Box Out - Good Results
