swapped trans coolers (pics)
Old 01-23-2005, 03:36 PM
12 Second Club
O3GMC's Avatar
Default swapped trans coolers (pics)
Stock towing package cooler
B&M 70264
New cooler is a few inches taller and about a half inch thicker, and a better design (hopefuly). I'll report back if I see any difference in the temp gauge.
Old 01-23-2005, 03:42 PM
11 Second Truck Club
Breeze's Avatar
Looks goog nice clean install. Let us know if she runs cooler.
Old 01-23-2005, 07:46 PM
If it runs cooler? My gauge only gets up about an 1/8" above 100 if its been running and idleing for awhile. On the road it never hits 100*.
Old 01-23-2005, 07:49 PM
ha, cool same one i got, same spot to. except your install is cleaner looking because you already had a factory one.
Old 01-23-2005, 07:58 PM
00blue53's Avatar
Looks like a good install. I would be interested if there is a difference.
Old 01-23-2005, 08:05 PM
12 Second Club
O3GMC's Avatar
wow, I guess the stall does create some heat - mine with the factory cooler would usually hover around 125 and get up to 150-160 if I'm getting into it
Old 01-23-2005, 08:22 PM
I guess i'll find out that too when i get the 3500 yank in. Didnt think about the stall making more heat around town.
Old 01-23-2005, 08:35 PM
00blue53's Avatar
I'm going with a stall pretty soon as well. Just curious, what made you decide on this cooler? Was this the biggest cooler you could find? Mine got to around 150 in 70* weather the other day so I'm interested to see what it runs in 90-100* heat.
Old 01-23-2005, 08:39 PM
SimpleManLance's Avatar
thats the same cooler i got only i mounted mine in series with the factory one. mine is mounted behind and up a little from the factory.
Old 01-23-2005, 08:58 PM
dragonman0325's Avatar
So where does your tranny temp run LadiesMan? I'm about to install my TB converter and am wondering if I should expect much heat.
Quick Reply: swapped trans coolers (pics)
