Swapping a 5.3 off an automatic into a manual truck
Hi, I have a 2002 Silverado 1500 4.3L manual, I just wanted to know exactly what I need to be able to swap a 5.3 off of another truck into it, the other truck was an automatic, I picked up the engine and harness but wanted to know what else was necessary, thanks!
Check the V8 swap sticky. It will basically be the same. I think the manual part is just bolt on and go but I could be wrong
I think this guy wants to keep the manual red.
I'll look for that piece for you though shoulda told me I bet I can find one
Nah he is gonna cut a hole in them to fit the stalk he said
I am in the market for that same plastic piece. I read on some past threads that the trailblazer or s10 will work. Its close but is too short once I found one and installed it. I have looked around on craigslist where junk yards advertise recent vehicles but no luck. Almost tempted to just put a new column in idk. I cant think of anything you will need in the transmission department it should mate right up, but the v8 sticky is best bet for info for sure.
Now you guys make me want to hunt for some gold.... Gonna charge extra for that
makes children cry
the 01+ 4.8 flywheels work; just ensure your new clutch kit matches your hydraulics (slave cyl quick-connection), and buy a flywheel to match that kit. some had alignment pins, and others didn't - which affects some of the pressure plates bolting flat (if not drilled for the pins... though some are universal & have the holes).
the fuse block (if pulled from an auto's engine harness) likely won't have the purple jumper wire required for the clutch safety switch. just transfer that over from your 4.3 harness, or you won't get a signal to the starter relay when you turn the key.
RedXray (08-21-2021)
RabidStreetRacer
10-16-2011 10:53 AM
