Switching to mobil 1 synthetic tomorrow-10w30 or 5w30?
Re: Switching to mobil 1 synthetic tomorrow-10w30 or 5w30?
I only have 5100 miles
I changed it after the first 100 miles and
used Mobil 1 5w30
I see alot of comment here in the post about it being
real thin - and they are right - It is real thin.
At 6k I will change it again using Mobil 1 10w30
I also use a GM PF 59 filter longer than the PF53.
I have used Mobil 1 10w30 in my 91 since new - under the valve cover is like new and my oil pressure went up in both trucks after the switch.
used Mobil 1 5w30
I was under the impression that it wasn't a good idea to switch to synthetic until after the complete break-in period.
i switched over to mobil 1 10w30 at like 15K, i now have 35K on my truck with no problems. i change the oil ever 5K miles, and when i changed it last weekend the oil still looked somewhat clean. and if anyone is gunna cause premature oil wear its me, my throttle only has two positions, ALL and NONE.
I read that it is bad to switch to synthectic after a long period of time. here is a good link.click on The Engine Oil Bible on the left.
http://www.chris-longhurst.com/carbibles/
Not saying you shouldn't run it at all, just saying that you should probably let the engine properly break in with dino oil first. I've running Mobile 1 10w 30 since around 25k and everything is going smooth.
99
I switched both my trucks over early - with never a problem - my 91 has 120k on it with tons of mods - also think about the number of veh out there that are
factory fill will Mobil 1 - Vette, Porsche, etc....
