Switching Octanes
Switching Octanes
I did the calculations today and found that every fill-up would only cost me $5 more if I ran 93 octane fuel as compared to 87 that I run now. I also know that LS1 f-bodys are supposed to only run 93 octane to run correctly. So my question is: Is it worth the switch (hp and mpg wise) to 93 octane?
Thanks
Thanks
When I first got my truck and Before I put my supercharger on I ran a couple of tanks of 87 octane than I tried 91 octane is was about 5.00 more to fill up and got better gas mileage. It worked out to be a savings of 2.00 dollars a tank full
Originally Posted by Quik
honestly just run 89 unless your tuned for 93 and have mods.
I ran 3 different types of brands. Shell, Chevron, and Exxon. All 87 and 89 oct fuels from them made my truck clatter under mid to upper rpm acceleration. I placed 93oct fuel from all of them and no more clatter. It did this from day one.
After I had Nelson's 93 oct tune I got use to putting 93 oct fuel in with no clatter either.
A few months ago I had Allen Nelson take my tune out and put the stock one back in. I had it removed for warranty issues with brakes and a GM rep taking a look at it.
Anyways, I went a head and tried placing 87 and 89 back in it. Clatter came back just like it did when I bought it. It now has 24,000k and I'm back to 93 oct fuel again with the stock tune.
Mine just may have a slight bit more advancement in the program. I'm not sure.
The 4.8 & 5.3L engines may take to 87 oct with no problems due to the lower compression. I just know mine does not like 87 or 89oct fuels. Even from the better brand gas stations. I only use chevron and Shell primarily. I've tried different station locations as well with the same results. I thought maybe a few of them had bad gas, but not all the different ones I tried I would hope.
I guess my engine is spoiled!
Jim
5 year bitches!
Originally Posted by CHEVY6000VHO
I tend to differ with you on that 100%. My LQ9 6.0L is supposed to run without problems on 87 oct fuel. Of course with stock PCM tune. I don't think so.
Jim
Jim
Just as a reference lets say you average 15 mpg with 87 octane at $2.90 a gallon. If you had a 25 gallon tank you would spend $72.50 to fill it up and ideally you would get 375 miles from the tank. Now lets say you switch to 93 octane and pay $3.10 a gallon, then you'd spend $77.50, which as you said is a $5 difference. Now lets say you get 16mpg, then you would ideally get 400 miles from the tank, and 425 at 17mpg. Now for the fun math, lets say you drove 1,000 miles at 15 mpg, you would spend $193.33 in gas (87). At 16 mpg you would spend $193.75 for gas (93), and at 17 mpg you would spend $182.35 (93). So if you are running 93 octane and only see 1 mpg difference, every 1000 miles you would be spending .42 more, but at 2 mpg difference you would save $10.98. Hope this helps a little.
doesnt your truck state preminum only but can be had to run on lower if necessary? i know cause i have the same motor well same as it was stock as yours at one time that came from a SSS. you run 10.1 they run 9.5 and its plenty for 89. you have higher CR which needs more octane
This tells me they were wrong:
http://www.powerblocktv.com/crate/crate.html#12
Jim
