Synthetic trans fluid
Old 10-07-2004 | 02:03 PM
  #21
Exclamation
Originally Posted by 2redgmc
Might want to find a new transmission guy.
You're right... I guess FLP must not know anything about transmissions either because I believe they say the same thing.
Old 10-07-2004 | 02:08 PM
  #22
snoman's Avatar
Are you trying to say that synthetics don't dissipate heat better that mineral oils?
Just to let everyone know I have a trans temp gage on my truck and when I changed from the factory fill to synthetic ATF I dropped 10 degrees from 195 in stop and go traffic to 185.
I guess you did not read my post correctly did you? Go read it again. Also bear on mind that it is theoritically possible for the parts to be hotter while oil is cooler because it is absorbing less heat from them.
Old 10-07-2004 | 02:09 PM
  #23
MacADaYear's Avatar
I work for a synthetic lubricant manufacture
We also sponsor the site
Ah, so to say you have a biased opinion might be on track
Being a sponcer means nothing more than you pay the monthly fees ...
Old 10-07-2004 | 03:02 PM
  #24
I did not say that they did not anything about transmissions I'm sure they do.
But transmission fluids might be a different thing.
I know of several transmission shops that recommend synthetic transmission fluids.
If you took them a transmission that has synthetic transmission fluid in it do you think they would know?
Old 10-07-2004 | 03:03 PM
  #25
budhayes3's Avatar
PT's Slowest Truck
I read somewhere, (think it was here), that the synthetics are too "slippery" for the 4L60E's...something about not allowing for proper friction surface characteristics. I dunno, the trans is the only place that I stick with the dino stuff, just old school that way I guess. I've got synth everywhere else.
Old 10-07-2004 | 03:04 PM
  #26
Or might be that I have better information about ludricants.
I was giving you a hint as to who I work for.
Old 10-07-2004 | 03:11 PM
  #27
Synthetic base oils are not "slipperer" than a mineral base oil.
Additives are what provide the lubricity and in the case of a Dexron?mercon fluid the additives are the same in a mineral base ATF and a synthetic ATF
Old 10-07-2004 | 03:18 PM
  #28
MacADaYear's Avatar
They arnt what? What is slipperer?
Old 10-07-2004 | 03:28 PM
  #29
good question
Budhayes3 posted
Old 10-07-2004 | 03:29 PM
  #30
budhayes3's Avatar
PT's Slowest Truck
How bout "slicker"? Souds good to me.
Quick Reply: Synthetic trans fluid
