tac mod #
tac mod #
need a tac module # to use a 90mm ls2 throttle body on a 04 chevy truck.got the spear tech harness already.does a tac module even exist to make this tac and throttle work.dont wanna use the dr x box so need help thanks guys
This place sells wiring pigtails if that helps any. It is probably just figuring out what the stock wires do and wiring up something to change the pin locations...
http://www.eficonnection.com/eficonn...omponents.aspx
12574221 is that it?
Speartech sells a tac module also
Yikes like $150 for a new one. Junkyard time!
There's one on ebay for $75 if that is what you need.
well i know guys but i had used the drx box before and had lot of little issues so decided that tac mod was more straight forward.i was just trying to see if i had the right mod. for thr ls2 throttle body in a 04
GM1697
09-09-2015 01:52 PM
