In-tank fuel pumps for trucks?
Old 02-25-2005 | 07:29 PM
Magic Chicken's Avatar
Default In-tank fuel pumps for trucks?
What in-tank pumps are you guys using? I just found out that Racetronix doesn't have a compatible system for me so I need to find some other suggestions. Will be running 62# injectors supporting 700+ rwhp.. Thanks.
Old 02-25-2005 | 07:52 PM
parish8's Avatar
single digit dreamer
they have something just for you but dont really like to sell it. probably take you a couple of months to get if you could talk them into selling you one.
check it out, lots of pic's >> http://www.neufamily.org/03html/fuelsystem.html
Old 02-25-2005 | 07:57 PM
do you have a part number for it?
Old 02-25-2005 | 07:58 PM
chris99gmc's Avatar
You might want to look into the Fuel Systems that Speed Engineering has out now. They look really nice for high HP applications for our trucks.
Old 02-25-2005 | 08:20 PM
parish8's Avatar
no, it is a build to order thing that you have to get thru them and they only put them together when they have time , it is a nice set up though.
Old 02-25-2005 | 08:45 PM
CHarris's Avatar
The walbro one for the 2004 H2 Radix is a intank pump. PITA to install but works great. No noise
Old 02-25-2005 | 09:21 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
two walbro gss340s, $4.79 in brass fittings, some marinetex, a relay, a hobbs switch and some wiring and you have the same thing that racetronix sells. It's an easy thing to do, and you can do it on your own time instead of sending your fuel pump carrier to Canada and waiting.
Old 02-25-2005 | 09:32 PM
chris99gmc's Avatar
I recon those are the In-line walbro pumps... So you think that you could run two in-lines and have the stock in-tank pump flow enough fuel to get the gas to those pumps?
Old 02-26-2005 | 04:49 AM
L-EATER's Avatar
11 Second Truck Club
No, he is talking about building your own dual in-tank setup. I did the same thing and it wasn't too hard. Far easier than dealing with racetronix.
Old 02-26-2005 | 09:40 AM
parish8's Avatar
i was a little worried about trying it myslef, not sure what kind of wire to use inside the tank or what kind of terminations. that kind of thing.
the price they charge isn't too bad once you add up all the stuff they use but they are dificult to deal with. no phone and 2 days to return emails sucks.
i did just order some injectors from them and got them in less than a week
Quick Reply: In-tank fuel pumps for trucks?
