Tapped Valley Cover and Valve Cover Clearence on L92s
Old 03-30-2011, 12:44 AM
I have a gauge for that
Atomic's Avatar
I kind of want to tap the cover and run it to a T off the driver side valve cover to a catch can and back to the intake with a breather on the driverside valve cover.
Old 03-30-2011, 01:26 AM
Baltimore Whore
Mangled03gmc's Avatar
Buy my fabbed ones, they will work just fine
Old 03-30-2011, 01:40 AM
Atomic's Avatar
Still havent seen a pic of the bottom :p
Old 03-30-2011, 01:56 AM
Baltimore Whore
Not sure what you wanting for the bottom.. But will have you a pic soon.. They should clear any roller set up, are atleast a 1'' taller then stock covers.
Old 03-30-2011, 07:50 AM
JoeyGC5's Avatar
Originally Posted by Atomic
So 2 questions;
1.) Will LQ4 Valve covers clear the stock rockers on L92 heads?
2.) Has anyone just tapped their valley cover and install a fitting and ran some line for the PCV system similiar to the LS6 style instead of just buying the LS6 stuff?
1.) Yes, but as noted all the baffling and a small bit of clearancing on a side rib need to be done to clear the stock ratio rocker arms. At least thats what I had to do on my 416's valve covers to fit the ported L92's.
2.) On my nitrous 5.3 motor I tapped and added a ls6 style nipple with no issues. I did use a breather on each valve cover and then choked down the line size from the valleyplate nipple to get rid of that slight oil smoke on startup and idle.
The_W
10-28-2015 09:00 PM
subeone
08-19-2015 07:44 AM
BlackGMC
08-17-2015 07:07 PM
jroctpb
08-11-2015 03:52 PM
low2001gmc
07-21-2015 02:09 PM
Quick Reply: Tapped Valley Cover and Valve Cover Clearence on L92s
