Taylor 10.4 wires
Taylor 10.4 wires
Taylor Cable 79206 - Taylor 409 Pro Race Spiro-Wound 10.4mm Spark Plug Wires - Summit Racing Equipment
Are these the Taylor wires some are running? Instead of flowers and candy me and my better half buy each other usable gifts for v-day. I got the sift this year she wants a pair of ugg boots. Fml. Thanks.
Appreciate the heads up. Is it worth putting a new set of stock wires on? I'm fixing to put on my cal speed lt's, and am gonna put new ngk tr55 plugs in along with some denso 02 sensors. Truck has 145,xxx on it. Not going for looks just best decisions.
I would do the headers first, because then you will be able to see if the plug wires or boots are touching anywhere. If so, you can get a set with angled boots. My stock boots touched the headers in a couple of places (LPP 1 3/4" LT's), so I got some angled boot wires and they did the trick. Tr55's gapped at .055" are a good choice. And you only need to replace the front O2's, as the rear only monitor the cats and can be tuned out.
But low-mile stock wires aren't a bad idea if you don't have any header clearance problems. I picked up a low-mile stock set from a member on here who upgraded for the cost of shipping.
Appreciate the reply guys. I've had my rear 02's shut off for a few years now via hp tuners. I have gutted cats.. I've been getting a few 02 heater codes and fuel mileage has fell of 1-2 mpg. So I'm gonna do everything all at one with a fresh retune.
Probably cheaper than stock wires from AC Delco too.
