tb for marine intake
Originally Posted by dajodsterman
whats the biggest tb you can use for the marine intake?
Only reason I ask is because I've seen people use Mercruiser blocks and electronics in some mild race cars. They even had the Mercruiser engine cover on it.
Jim
You won't get any gains porting the throttle body or installing a larger on the Marine L31 Intake. It will do just fine with the 78mm throttle body. The manifold itself flows much better than the stock one at high RPM and the large internal volume makes air flow through the throttle body efficient. I do recommend removing the EGR diffuser plate from the throttle body blade since there's no EGR blowing against the bottom of it.
Pontiac Derek
09-19-2015 01:49 PM
