tbss intake install
tbss intake install
im gonna put putting a new style intake on my ss. I've read all the ins and outs but have a quick question.
im gonna use a adapter so i can run my stock tb till i get a ls3 and x link. the adapter is in the mail and missing the o ring that comes on it. does anyone know if this o ring is biscally the one on my new style intake still? meaning i can use it and the one off my stock one for adapter?
also are the intake gaskets the same for both?
and i can't find any solid info on the evap system. is it pretty much plug and play?
I haven't used that adapter. I just found a 90mm TB on tech for cheap. Swap is quick and easy as long as you have your fuel rails figured out. If you don't have a New style evap solenoid. I have a new one in the wrapper from GM I can part with..
i would like to know what throttle body to use also if your doing a tbss swap on a '01 truck that has a 3-bolt, cable throttle body... what would i use? did they make a cable 87/90mm tb? or do i need to order some kind of adapter and bigger tb or do they have an aftermarket tb that is 4 bolt, but cable pull?
Suburban2500
07-14-2015 02:10 AM
