TBSS Intake Manifold and 90mm TB
I read through the "Intake" sticky and couldnt really find my answers so I will have to start a thread -
What my plan is with my new 6L build is to swap in the TBSS intake manifold and the 90mm TB - there is a harness converted that i found that makes this possible for the older harness plug to work the DBW with the new TB....so my question is will i fit and what sort of gain is there over the stock truck intake and 78mm TB? I have found both the intake and TB for the TBSS on gmpartsdirect that are relatively cheap, so i was thinking if it fit, thats what I will do.
BTW Thunder what ever happened to that black stepside you had?
High on diesel fumes
i know what you are saying - i just wanted to run the 90mm TB, but if the TBSS intake isnt any better at all compared to the truck one with 78mm then its not worth it. I guess my thinking is with the 12mm differnecne in the TB there has to be some gain i would think. If the case is "no gains" then im going to put the stock intake back on...
What black stepside are you talking about? This is the only truck I've had while I've been on this site. You might be thinking of 01thunder....that's a different guy
maxspeed05V
08-17-2015 08:41 PM
