Tbss problems!
Tbss problems!
Ok so I did the tbss swap with a nnbs throttle body, I'm finally getting it tuned an my tuner says it is showing 100% at 3/4 throttle an when you do floor it the comp looses connection to the tps, truck goes crazy an into limp mode. It's even showing 13% throttle at idle or the truck off. I have the xlink, any thoughts? Truck is my dd.
Could you post a pic? Some TB require the pink wires to be cut & some not. When I installed my 90mm tb I miss read the direction & cut the pink wires & it did the same thing that yours is doing
