TBSS Throttle Body Problem
I installing a new LS2 intake set-up on a 6.0 and have discovered problems like this surfacing up. I called speartech yesterday and they said that in 2006(and newer) Chevy did something different to their throttle system. Speartech said that in order to possibly to get this 90mm LS2 tb to work, I would have to change the tach module and pedal assembly. Speartech also said that I would throw ses codes too..........Which x-link did you use??? The one from speartech or scoggins???
James
James
James
James
http://www.torquerush.com/
im almost positive he's using the DR-X Link.
I was able to duplicate the P1516 code in my driveway with the key in the on position and not running today. I put a heavy brick on the gas pedal and verified the TB was open 100% then lightly pushed on the blade in the direction to close it and found that it doesn't take much pressure at all to cause the P1516 code to show up and go into REP. Looks to me like it has nothing to do with the springs in the different TB's like people seem to think. I think the motor in my TB is too weak to handle high airflow turbulence. Could be a problem with the truck TB in general but I won't know until I get to test a new truck TB against a car TB. I have access to a new truck TB but not a car one so if the new truck one works I won't be spending money on a car one to test it, unless someone wants to loan me one.
Were you pushing the blade more open, or toward the closed position?
James
James
I actually tried both, but pushing it to the open position didn't do anything. I couldn't even move the blade open any more so I'm sure it was at WOT. When I pushed it in the closed direction it immediately went into REP and gave the P1516 code and I didn't have to push very hard at all.
