Is there a better alternator? 01 Tahoe
Old 06-02-2005, 01:04 PM
Question Is there a better alternator? 01 Tahoe
Is there a better alt. out there for a 01 Tahoe it has been like this since I bought it. It seems to be very weak. It was hot yesterday and with the A/C on the lights dim a little.And the stereo probably doesn't help either. I was talking to a guy and he was saying something about the later models have a higher amp output alternator. Is this correct?
Thanks for any help
Old 06-02-2005, 01:35 PM
Bish's Avatar
Thanks for any help
I believe mine came stock with a 130amp alternator. It has been replaced twice. At about 60K I started to get the voltmeter bouncing and the lights flickering at random times. The first time I replaced it I went with a Napa 130amp replacement. That one lasted about 60K and started to do the same thing. I finally went with a 200amp model from alterstart and it has been flawless for 20K now.
BTW-I my Tahoe is loaded with about 1200 watts worth of stereo and an XM radio receiver so my electric loads are a little higher I suspect.
Old 06-02-2005, 01:48 PM
is there any other mods I would have to do with the 200 amp alt? How much was it?
Thanks
Danny
Old 06-02-2005, 01:53 PM
zippy's Avatar
kinda helps to know which alternator you have on there now. there are two different amp versions used on your truck.
Old 06-02-2005, 02:10 PM
oh man I don't know which one it is how can I tell them apart?
Thanks
Danny
Old 06-02-2005, 03:36 PM
SSlow 4.8's Avatar
Look closely at the alternator.. there should be a sticker or metal badge on it and somewhere it should say a number followed by an A or they might spell out "AMP"... so it might be something like 130A for an example.
Old 06-02-2005, 03:59 PM
Cool I'll check once the wife gets home.
Old 06-02-2005, 06:00 PM
Bish's Avatar
Thanks
Danny
New wire from the alternator to the battery. Can't remember the exact price but it was around $225 or $250 if I remember correctly. It was a direct replacement with the exception of the new wire.
Old 06-02-2005, 06:18 PM
BishSTS's Avatar
Sorry to hi-jack your thread, but is your last name Bish??
Old 06-02-2005, 09:25 PM
Bish's Avatar
Bishop. Been called Bish by friends since about 4th grade Guess it just stuck.
Quick Reply: Is there a better alternator? 01 Tahoe
